I bought a pressure switch from Napa today, they had one on the shelf, box looked old stock. I hooked up a regulator and a pressure gauge then checked the pressure needed to close the circuit, it was 75-80 PSI!!!Don Elliott said:When mine stopped working, I bought two new ones. I checked that they both worked by using my compressed air nozzle and a continuity checker to see that they switched when I applied the air pressure. They both worked at about 30 - 35 psi air pressure. I put one in and it was good for 5 years. Then it failed so I re-tested the new spare I had in my tool box for 5 years. It wouldn't work even at 110 psi. So I chucked it in a lathe and turned it to find out why. There is a disc about the size of a dime that closes the contact. It was black with oxidation which I assume must have developed over that 5 year period.
I don't know why they don't use stainless steel for that disc.
Don
That is way to high!
Probably oxidation like Don said!
I returned the switch.
I will order one from TRF and hopefully it will connect at 35-40PSI.
I guess that any brake switch would work as long as it has an 1/8 NPT thread with spade terminals.
Randall, mentioned an early Ford switch?
Part #_______________
Nothing is ever easy!
Lyle
