TexasKnucklehead
What length are bolts HB.0968 and HB.0971?
According to my parts manual 2)HB.0968 are used to secure the water pump body to block, and 1)HB.0971 -the latter probably longer since it also goes through the bearing housing and must be inserted before the pulley is pressed back onto the shaft. I thought I had been careful to keep these bolts in the proper order -but I've ended up with three different lengths, not two. Moss and VB have different part numbers for their bolts. Can someone provide me with a cross-reference to the part numbers for bolts/washers?
-While I'm asking... is there a trick to holding a Key onto a shaft while the pulley is slid onto it?
