DougF
This is what I have been taught in my sales training on battery maintenance.
The corrosion that you see is caused by expansion/contraction caused by ambient temperature or from the heating of the battery itself. The plastic case does not expand or contract at the same rate as the lead post, allowing vapors to escape.
The felt rings that have been mentioned are treated to neutralize this escaping acid vapor.
If you spray the terminals with a battery protectant in conjunction with the felt rings, it should keep the terminals clean for the driving season. You will still want to check them periodically.
I'm not certain that petroleum jelly is the best way to go. It may not be conductive and cause a small loss of electrical flow.
