I am sure this will be the first of many questions.
I have both the clutch fork set-screw safety wire and the set-bolt removed, and the locking bolt and grease fitting removed from the right side of the transmission. The shaft will begin to slide out but the clutch fork will not slide along the shaft, or rotate around the shaft other than a few degrees. I have tried penetrating oil but have not had any success. What have I failed to do?
How does one remove the speedometer drive once the set screw is removed?
Thanks.
Ron
Thanks.
Ron
