glemon
I sure am happy it is building pressure, but I wouldn't say I was sweating bullets I lubed everything up, so wan't to worry about wearing it out spinning it on the starter, but I was worried about the possibility of maybe having some oil line blocked or a pump issue that would require pulling or dissassembling the motor in situ.
I wired up the ignition last night just to see if it would fire, not luck, but I am not asking for help at this point, I did test for spark, but haven't verified if the float bowls or full or done anything but a real quick and dirty timing check, I will dial it in a little more precisely tommorrow night and see what happens.
Thanks for words of wisdom and support, Greg
