TR5/TR250 TR250/6 accelerator shaft bush
glemon
I just recieved a nylon accelerator shaft (not throttle shaft but the shaft that zig zags off the pedal and behind the motor) from a major brit car supplier that specializes in Triumph, I understand the idea of using a nylon bush for wear purposes, but how the heck do you get it on. I called the tech line and they said cut one side and sort of spiral it in, even with this modification and my twisting and pushing it appears the chances of getting it on short of using a large hammer and mangling ir to death are somewhere between slim and none, anyone done this succesfully and if so how?
poolboy
You'll become aware of alternative choices before long, but if you used one like the Moss one, as I did, you'll have to do a bit more than make a razor or knife cut to get it to fit. You'll need to take a sliver out or use a saw blade that removes a bit of material as it cuts.
One thing, once it's in it ain't gonna fall out.
AltaKnight
I had a heck of a time getting mine installed but with a lot of cussing and some VERY hot water and liberally coating the thing in washing-up liquid I was able to jam it n about 3/4 of the way around then shove it in the resy of the way with a blunt screwdriver; of course the 1st 6 times it popped out and the hunt was on to find the darn thing. Then I had trouble getting the throttle x shaft back in through those new bushings!
mrv8q
Paul covered this subject nicely in his post:<span style="text-decoration: underline"> Replacement throttle shaft bushings for TR6</span> on 3.20.07.... Don't know how to link to old post, obviously.
BobbyD
Those bushings are near impossible to install correctly so I went the Art Lipp route as Paul mentioned above. If you insist on originality take a very close look at the design of the bushing and you'll find that the opening is actually wider at one end and then tapers to the shaft diameter at the other end. As a result the drivers side bearing must be installed from inside the car and not from the engine bay. If installed from inside the driver's side, the wider opening is available to accept the shaft. The passenger side is just the opposite and should be installed from the engine bay.
As far as actually getting them in to the hole..........I had the engine out and worked from the engine bay figuring it would be easy that way. I used hot water to soften them, a lube to make them slippery and a wide flat bladed screwdriver to work them into the hole. After they were in I discovered the driver side had to be done from inside the car to get the shaft to fit through the hole. So I took them out, emailed Art and got his kit.
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
glemon Wanted TR250 Wheels Triumph Classifieds 1
conan69 TR5/TR250 TR250 seats Triumph 1
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
angelfj1 TR5/TR250 Starting a TR250 that's been sitting for 10 years Triumph 12
angelfj1 For Sale TR3, 3A and TR250 Parts for Sale Triumph Classifieds 6
Retired2020 TR250 steering column bushing Triumph 2
Retired2020 TR5/TR250 TR250 smith gauge Triumph 7
S TR5/TR250 "New" TR250 on the horizon Triumph 0
apbos TR5/TR250 TR250 rolling chassis and body for sale Triumph 3
DocDup1 General TR TR6/TR250 Steel Wheels Triumph 3
DocDup1 For Sale TR250/TR6 Steel Wheels Triumph Classifieds 5
MadRiver TR5/TR250 TR250 Radiator Cap Recommendations Triumph 1
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
C TR5/TR250 Tr250 registry Triumph 6
Got_All_4 TR6 Oil in the coolant in my TR250 Triumph 6
oldbagpipe For Sale '69 TR6/TR250 Seats now available Triumph Classifieds 0
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
S For Sale Triumph TR250 Factory Workshop Service Manual on CD/ROM – 1968 Models Triumph Classifieds 0
K TR5/TR250 TR250 question [Not asking for a friend] Triumph 17
T TR5/TR250 TR250 wiper switch and motor Triumph 1
T TR5/TR250 What lubricant for TR250 wiper box and cable? Triumph 2
glemon General TR TR250 Steering Wheel Options Triumph 6
P Wanted WANTED To Buy a TR4 or TR250 Triumph Classifieds 3
T For Sale TR4 TR250 Rear Fenders Triumph Classifieds 2
T TR4/4A TR4A/TR250 what are they worth Triumph 8
M Wanted Wanted TR4A/TR250 passenger side front fender Triumph Classifieds 0
M Wanted WANTED TR4A or TR250 fendet Other British Classifieds 0
busybrit Wanted TR4, TR4A, TR250 Rear light WANTED Triumph Classifieds 0
glemon TR5/TR250 Stumped TR250 Running Rough--Follow Up Triumph 3
glemon TR5/TR250 Stumped TR250 Running Rough Triumph 8
J For Sale Triumph tr6 tr250, tr5 parking brake improvement kit Triumph Classifieds 1
R Wanted TR4A / TR250 Center Console Triumph Classifieds 1
B TR5/TR250 Registry for TR250's? Triumph 1
brgrmyster TR5/TR250 1968 TR250 original emissions lines Triumph 0
RobT For Sale Triumph TR250 - $32K Triumph Classifieds 2
TRopic6 For Sale Flywheel for TR250/'69 TR6 Triumph Classifieds 0
B Wanted TR250 passenger seat Triumph Classifieds 0
M_Pied_Lourd TR5/TR250 Started my TR250 Restoration Project..... Triumph 16
T TR5/TR250 Original TR250 sun visors Triumph 0
Marvin Gruber TR5/TR250 TR250 Alternator Triumph 13
glemon TR5/TR250 TR250 Prototype Triumph 10
flylear45 TR5/TR250 TR250 resto project log Triumph 12
M TR5/TR250 No spark on TR250 Triumph 17
David Townsend TR5/TR250 New TR250 Limited Edition Print Triumph 0
