TR2/3/3A TR2-TR3-TR3A Top Question
mountainman
Can someone please tell me the difference between TR2-Tr3 and TR3A Convertible tops and frames. I have a 59 TR3A and ordered a new top but, the seams
do not line up with the second or third bows of the frame. Could I have gotten a TR2-Tr3 top by mistake?
Thanks
Greg
Moseso
The top bows are the same through the whole run of TR2, 3, 3A & B. The differences are in the windows (one in the TR2 -- three, later) and the snap fasteners used to attach to the windscreen.
The reason your bows do not line up with the seams in your new top is that it's a different top than the last one. The webbing will have to be adjusted to make the bows line up with the seams in your new top. They aren't all the same.
How big is the difference? Are they off by less than an inch, or inches?
Twosheds
You will need to adjust the webbing attachment to the top bows to get the bows to align with the seams on the new top. I use the Trial and Error Method. Or Trial and Success Method.
mountainman
mountainman
Moseso, I adjusted the bow closes to the rear to fit the first seam. The 2nd and 3th are off by about 6" to long[toward the front] Shouldn't the bows be completely open. I mean lock into each other?
Thanks
Greg
luke44
Hi Greg - I'm following this thread with interest. can you post pix of the frame w/o top, and then one with?
Moseso
Thanks
Greg
No. They shouldn't go all the way out til they lock. The webs will hold them in the right places -- where the seams are.
My top fitting procedure was to fit all the snaps to the top, all the way around --
Then, measure from the stud hole to the first seam, first seam to second seam & second seam to third seam -- all out near the inner ends of the seams, nearest where the webs will actually be --
Set the webs to the bows, using these measurements --
Erect the top and note how far off you are -- if you've done the measuring well, it will be pretty close, but you still might need to adjust 1/2" one way or the other.
NOTE: I found the TRF webbing (I don't know about anyone else's) to be impossibly stretchy. I discarded it and used a nylon webbing that I had bought at a surplus store ages ago. It's heavier gauge, and doesn't stretch. WYSIWYG measurements.
mountainman
mountainman
Moses, I am alittle confused. If you don't spread the frame all the way out to"lock into itself " what keeps it from folding back and down?
Greg
Luke, my wife has my camera so when she get's home I'll post a pict.
Moseso
Top bows erect:
The web to the middle bow affects where it rotates to when locked open (that one must lock) on the pivot screw at the attachment bracket. Note the "air gap" between the end of the third bow and where it would rest against the middle bow.
Moseso
I realized I might have caused this confusion -- does my last post clear it up? The middle bow, as you realize, must lock open.
Procedure for erecting the top -- in case you haven't heard this one...
Pull up the top bows -- but do NOT pull the center bow all the way up and locked.
Snap the top on, all the way around.
Pull up on the center bow, at the locking joint, until it snaps home.
This is more easily said than done, with a new top -- or a cold top. Two people, one on each side of the car, can be a real aid to this part of the process.
mountainman
mountainman
Thanks Moseso, The pictures helped alot. Now I see how it should work. Did I understand that you put all the lift the dot and tenx fasteners on the top first just spacing them between each post and then did the frame?
Greg
Moseso
Yes. My top (an NOS Amco, via eBay) had the Tenax fasteners already on. I added the LTDs to the rear, and then set the webbing on my bows.
Erect the top -- observe how the bows line-up with the seams -- remove the top -- adjust the webbing/bows -- repeat as necessary.
As John says, trial-and-error.
In my trade, it's called "cut-and-try." Fortunately, no cutting is involved here -- til it's all proved out. Then you can cut away any excess webbing.
Tinkerman
Great thread guys! This one is going into my BCF notes for use when I get to that point.
Thanks, Tinkerman
mountainman
mountainman
Hey Dick join me in thanking Moseso he inlighten us on fitting the bows and top. THANKS Moseso
Greg
J For Sale Triumph TR2 TR3 TR3A New Moss Motors Black Karvel Style Carpet Kit Triumph Classifieds 0
S For Sale Triumph TR2/TR3/TR3A/TR3B Workshop on CCD/ROMManual – 1953 - 1962 Models Triumph Classifieds 0
Lukens For Sale Classic center armrest/console for tr2, tr3, tr3a, tr3b, and tr4 Triumph Classifieds 0
J For Sale Triumph TR2 or TR3 elbow trim Triumph Classifieds 0
S TR2/3/3A tr2 and tr3 back trim above the back cover Triumph 0
S TR2/3/3A early tr3 and tr2 kick panels Triumph 3
S TR2/3/3A TR2 and early TR3 wipers Triumph 7
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
T Wanted WTB TR2/TR3 Hood/Bonnet Latch Assembly with Prop Rod Triumph Classifieds 0
T TR2/3/3A About to strat a full restoration TR2 / TR3 ? Triumph 66
G For Sale Original Kastner "D" Camshaft for Triumph TR2 TR3 TR4 & Morgan +4, Like-Nu Orig. $420 Triumph Classifieds 1
R TR2/3/3A TR2/TR3 transmission dip stick access Triumph 10
M TR2/3/3A TR2 TR3 oil cap decal Triumph 18
Rhodyspit75 TR2/3/3A TR3 & TR2 parts Triumph 0
arizonamike TR4/4A Collector's Originality Guide Triumph TR2 TR3 TR4 Triumph 1
T TR2/3/3A TR2/TR3 spark plug gap setting?? Triumph 8
K TR2/3/3A TR2 early TR3 windscreen stanchions Triumph 1
AngliaGT TR2/3/3A New Windshield for TR2,TR3 $150 Triumph 2
HerronScott TR2/3/3A Cutaway TR2-TR3? Triumph 1
M TR4/4A OE tr2,tr3,tr4 aircleaner up-grade!! Triumph 4
beaulieu TR2/3/3A This time the TR3 is one, or maybe a TR2 ! Triumph 12
gsalt57tr3 TR2/3/3A TR2/TR3 grill surround on eBay Triumph 3
TRJohn TR2/3/3A TR2 TR3 master cylinders Triumph 2
gsalt57tr3 TR2/3/3A TR2 vs TR3 front apron Triumph 4
Nanhook TR2/3/3A TR2 shoes Triumph 2
CJD TR2/3/3A TR2 Annual Triumph 6
S TR2/3/3A WTB a tr2 original grill Triumph 0
P TR2/3/3A TR2 Horn Mounts Triumph 7
mctriumph For Sale Tr2/3 scuttle mechanism Triumph Classifieds 7
S Wanted tr2 original grill Triumph Classifieds 10
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
A TR2 Transmission overhaul Restoration & Tools 0
D TR2/3/3A TR2 Flying Mile question Triumph 11
S TR2/3/3A tr2 muffler clamp Triumph 10
Southwarks TR2/3/3A TR2 door help! Triumph 2
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
A Wanted Girling Axle for TR2 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
S TR2/3/3A tr2 Triumph 18
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
J For Sale Triumph Tr2/3 seat foams Triumph Classifieds 1
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
C TR2/3/3A TR2 Axle/wheel bearing removal Triumph 2
71TR6 Set of 4 TR2/3/4 Connecting Rods Triumph Classifieds 0
P New member TR2 carpets Triumph 7
