TR2/3/3A Tr2 hood
sp53
Tr2 hood---I was cleaning out the barn and moved around some tr3 sheet metal I have had since 1975. I knew what I had there--- I thought anyway, but when I looked closer at the hood the hood has no fold on the back edge. I remember John saying his tr2 only had the cut edge with no fold on back. Are there any other differences on a tr2 hood? They must inner change with a tr3 because I bought this whole 1958 car in 1975.
The TR2 hood will have four air vents at the back and front brace bar will have two sets of holes drilled for the double spring latches
S
sp53
Thanks Marv the hood only has 2 vents. Did the 1957 and 56 tr3 have that cut edge on the back of the hood without the finish fold on the back edge?
CJD
Yes, the early TR3's also had the rough edge at the rear...I am pretty sure it is all the bonnets before they added the raised plinths.
S
sp53
I have owned a 1958 TS29xxx since 1973, and it has the fold on the back of the hood and flat panels on the hood and deck lid. I stripped it in 1973 by hand and the car was red on top with was Apple Green Lacquer from factory. I do remember at the time the hood was in primmer and I do not think it had the Green underneath. I remember that because paint remover would not work kinda sorta on the lacquer. The lacquer turned to maybe light gel, and I had to use lacquer thing to get off the lacquer
I just restored is 27036 and it is a 1958, but I used a 1959 hood. Both cars have flat panels also--- But what is different is the first hood I found with the ruff back came of 27036, but it was dented, so I went with the 1959.
After all that, and with the limited information I have on the subject. Heck I knew nothing about the ruff hood deal until John commented on it. I am convinced the change happed around TS 27000. I had great visons of people begging me to sell, but now —oh life
steve
S
sp53
So the 55 and 56 should have the rough cut hood, but the 55 has 4 vents and the 56 has 2 vents. Does that sound generally correct? Marv you have by experience become one of the few that would know.
steve
S
sp53
Because I find it interesting to discover something new about these cars, I will show what I think is correct for the 56, 57, 58 hoods. I have a 58 hood with a smooth hood no raised hinge and a 90 degree bend on the lower edge an earlier 58 hood with a smooth top and a cut edge, so it looks like a 58 could be either way. It looks like the 56 has a rivet and a cut edge because of what Marv and Mike stated and Mike’s picture. So, I guess the 56 is the unique hood because it has 2 vents, cut edge, and brass rivets on top to hold something-- probably some kind of backing for the hinge. And, TR2s are different—like Marv said.
steve
T Wanted WTB TR2/TR3 Hood/Bonnet Latch Assembly with Prop Rod Triumph Classifieds 0
newmexTR3 TR2/3/3A TR2-4 hood hinge gaskets Triumph 5
Nanhook TR2/3/3A TR2 shoes Triumph 2
CJD TR2/3/3A TR2 Annual Triumph 6
1955TR2 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 8
S TR2/3/3A WTB a tr2 original grill Triumph 0
P TR2/3/3A TR2 Horn Mounts Triumph 7
mctriumph For Sale Tr2/3 scuttle mechanism Triumph Classifieds 7
S Wanted tr2 original grill Triumph Classifieds 10
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
A TR2 Transmission overhaul Restoration & Tools 0
D TR2/3/3A TR2 Flying Mile question Triumph 11
S TR2/3/3A tr2 muffler clamp Triumph 10
Southwarks TR2/3/3A TR2 door help! Triumph 2
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
A Wanted Girling Axle for TR2 Triumph Classifieds 5
J For Sale Triumph TR2 or TR3 elbow trim Triumph Classifieds 0
S TR2/3/3A tr2 and tr3 back trim above the back cover Triumph 0
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
S TR2/3/3A early tr3 and tr2 kick panels Triumph 3
S TR2/3/3A TR2 and early TR3 wipers Triumph 7
S TR2/3/3A tr2 Triumph 18
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
J For Sale Triumph Tr2/3 seat foams Triumph Classifieds 1
J For Sale Triumph TR2, TR3, TR4 CAM SHAFT FOR SALE Triumph Classifieds 0
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
C TR2/3/3A TR2 Axle/wheel bearing removal Triumph 2
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
71TR6 Set of 4 TR2/3/4 Connecting Rods Triumph Classifieds 0
P New member TR2 carpets Triumph 7
W TR2/3/3A TR2 wiper motor mount Triumph 1
TRopic6 For Sale TR2/3 Brass Fuel Shutoff Tap [for parts] Triumph Classifieds 0
J For Sale Triumph TR2 TR3 TR3A New Moss Motors Black Karvel Style Carpet Kit Triumph Classifieds 0
S For Sale Triumph TR2/TR3/TR3A/TR3B Workshop on CCD/ROMManual – 1953 - 1962 Models Triumph Classifieds 0
Leatherman Wanted Red and black TR2 / 3 front emblem Triumph Classifieds 6
Jim_Stevens For Sale New TR2-3A inner sill assemblies Triumph Classifieds 3
C TR2/3/3A TR2 Chassis Clips Triumph 4
B For Sale TR2-3 Door Top Wood Rail Triumph Classifieds 1
P TR2/3/3A TR2 color questions Triumph 23
C TR2/3/3A Triumph Tr2 Down Under Triumph 2
T TR2/3/3A About to strat a full restoration TR2 / TR3 ? Triumph 66
CJD TR2/3/3A TR2/3 Guru Final Exam Triumph 59
R TR2/3/3A TR2 Scam Triumph 13
SASSAMON Wanted WTB Early Sidescreens and mounting hardware for TR2/3 Triumph Classifieds 4
JFS TR2/3/3A TR2 Rear Plate Lite on TR3A Triumph 10
M General Tech TR2 Slave cylinder Triumph 0
K TR2/3/3A Moss Europe has restored the Jabbeke TR2 Triumph 0
