TR2/3/3A TR2 fuel pipe for H4 SU carbs
2long
Hey, does anyone have the carb-to-carb solid pipe that runs from the fuel pump up to the carbs, and the two banjo bolts that the pipe is brazed to? I am resurrecting a Doretti and it has the incorrect fuel lines.
Dan
FWIW, TRF has the banjo bolts listed under SUAUC2698
No kinding I knew a guy that had like 4 of those lines lying around in the day. They are a solid pipe set up on the top with a very slight arch. Those small carburetors were not as popular. If you had the banjo bolts, it should easy to make. I think they were brazed, maybe soldered.
