1955TR2
I am encountering an oil leak problem that should be simple to fix but has me stumped.
I recently got my car back after some body and mechanical work was done on it which included an engine rebuild and reconnecting the oil sending unit. There is a fairly significant oil leak coming from where the oil sending pipe connects to the block. My initial thought was someone may not have installed the copper washers correctly because there is an inner and outer washer. I ordered new inner and outer copper washers from Moss and today I replaced these two washers and triple-checked I installed them in the correct order. I also replaced the stud end cap at the same time. Unfortunately, when I started the car to test if this fixed the leak to my surprise the leak is still there. I double-checked the tightness of the cap and retested but it's still leaking.
Does anyone have any ideas how to stop this leak/what might be causing this to still be leaking? Thank you.
