The TR Manual lists the dummy mainshaft as "essential" to rebuild the overdrive. However, as I recall, it can be done by just aligning by eye, or using a long screwdriver. Isn't that correct?
I had the luxury of a dummy mainshaft until my JB Weld broke on the perfectly matched key I'd made. Re-gluing with any accuracy would require that for alignment I remove the planet assembly I just installed with a the brake ring sealed. I'd like not to do that, and plan to just eyeball it with a screwdriver if that is good enough.
thx
thx
