When posting a classified ad, you MUST select a prefix from the drop-down next to the subject line. If you don't you will get an error and your ad will not be posted!
Can someone point me in the right direction for instructions on how to properly install a new soft top on a Wedge?
Also possible outlets where I can buy one?
Trying to help a friend in need.
Thanks
Mike
You might want to call Woody @ The Wedge Shop.....I know he must have done about 200 tops in the last 10 years plus. He also sells them too. I have done about 30 or 40 of them too! There are a few tricks to them where the window vent with folding or the materials the intersect in that particular region. The other bit of advice is to look at the holes for the hold down/header strip to make sure the holes are not over sized. If the are your going to bein trouble because the rivet to hold the rail down goes inside of the rail and a weather strip goes inside of that. If you use a bigger rivet you will bnot be able to get the seal in the track and it might work loose. If you have plastic snaps on the car itself replace them too with metal ones.
