mabbott
Hi, I could use some assistance with this one. I have a 73 TR6 that has one very dim head light on the drivers side. It's not a defective bulb.
Here is what I have observeed so far:
- Switched the drivers side and passanger side head lights and the the problem is still present.
- On the passenger side (that works)the bulb seems warm / hot but I don't have any basis for what it should feel like.
- With both bulbs removed and then plugging in the passenger bulb the light goes on.
- With both bulbs removed and then plugging in the drivers side (dim side)the light DOESN'T turn on.
- The voltage at the three prong plug behind the bulbs is 13+ volts.
Any ideas? Ground issue? Where to look?
Thanks,
Mark
Thanks,
Mark
