TR6 TR-6 Fuel Pump Diaphragm Failure [Red-type]
TRopic6
I finally installed the fuel pump I rebuilt over a year ago, and in less than 30 miles the diaphragm started leaking. I smelled fuel and found it wet underneath and dripping onto the oil cannister from the weep hole in the pump body.
I had used a kit with a red diaphragm, and it looks like the fuel (ethanol?) somehow separated the rubber stuff from the inner material. You can see where the rubber has seperated and even torn on one side. If you have one of these red ones, better keep an eye on it.
Brosky - great step-by-step on your Fuel Pump 101. I see your kit used a black diaphragm. It looks more substantial than my red one, which seems kind of thin and apparently the fuel started dissolving it (not exactly a good property for a fuel pump). Any problems with yours?
I put the old pump back on, a small, weird after-market one that looks like it was intended for an early Spitfire. It's 20+ years old but at least it works. Anybody else run into a problem with new diaphragms breaking down under ethanol gas? I hope the material in the valves will be OK.
Jeff
74 & 74.5 TR6
Adrio
I ran into the exact same problem with three kits last summer. Two of them were red ones like your (I bought them from Moss who asked for them back so they could analyze them) and one was a black one I got locally. All three failed exactly like yours did and also in about 30 miles or about half an hour. There is a thread on here about it. Remember to change your oil as some of the fuel may have found its way into the oil sump and now you wont have the proper lubrication from the oil. I found a lot of gas in my oil all three times.
I suspect the ethanol as well.
Moss gave me two new pumps free of charge in exchange for the two failed rebuild kits I bought from them. I have not heard anything back about the analysis. However A friend of mine (who sometimes is on here) has since bought kits from them and the kits seem to have a different diaphragm. I need to ask Frank how many miles he has on the new kit.
I am curious to hear if others are in the same boat.
mrv8q
FWIW, I believe M*ss was selling the red diaphragm, and T*F was selling the black diaphragm. I rebuilt mine, using the black, but have yet to try it out. Is there higher ethanol content in HA gas, than that stateside?
MLang99 TR2/3/3A Fuel Pump Diaphragm Triumph 7
charlie74 found- 1 torn fuel pump diaphragm Triumph 4
AndreL TR6 Conversion to electric fuel pump Triumph 14
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
D TR4/4A TR4a Fuel Pump Triumph 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
D MGB Fuel Pump MG 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
S fuel pump upgrade Spridgets 0
S Sprite Fuel Pump Upgrade Austin Healey 1
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
P XJ12 Fuel pump relay 85 Jaguar 4
petnatcar Fuel Pump Upgrade Austin Healey 2
R Electronic Conversion on an SU Fuel Pump? Restoration & Tools 2
T TR6 Fuel pump lines Triumph 2
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
R Electric fuel pump wiring Spridgets 4
T SU Fuel Pump Mounting Austin Healey 5
D TR2/3/3A More Fuel pump questions. Triumph 10
Donald1107 59 TR3A Fuel Pump Triumph 48
BobHaskell SU Fuel Pump Pressure Austin Healey 1
Cutrog1 Fuel Pump Ticking Austin Healey 13
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
S SU fuel pump servicing Austin Healey 4
71TR6 TR2/3/3A AC Fuel Pump Lever Triumph 10
E MGB 1965 mgb fuel pump removal MG 2
D For Sale Su fuel pump Other British Classifieds 5
D For Sale Su fuel pump Austin Healey Classifieds 5
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
vette A Quiet SU Fuel Pump Austin Healey 2
A TR4/4A AC Fuel Pump stuff Triumph 11
AngliaGT Fuel Pump Problems Spridgets 2
B SU Fuel Pump Parts Austin Healey 8
B TR4/4A Mechanical fuel pump vs electric Triumph 16
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
J TR4/4A Fuel pump saga Triumph 4
longbridgehealey Fuel pump racing, no gas Austin Healey 26
D General TR Fuel filter before the pump. Triumph 2
T 66 Austin Healey fuel pump replaced Austin Healey 30
C Well I Tried with a new SU fuel pump British Motor Corp 0
