davidk
Installing the HDVA Toyota conversion. Planning to have the stock flywheel lightened and have it and a new pressure plate balanced. Is the balancing required? I found a machine shop that will lighten it per the Vizard drawing referenced in another post, but can't find anyone to balance the assembly.
Didn't want to spend the money, but I'm also considering the Fidenza aluminum flywheel. If I buy it, will it and the pressure plate I have need to be balanced?
Thanks for your help!
