TR6 TR-6 Engine and transmission.
G
guyg4466
Honestly I am not sure what I have or its value, perhaps someone can help. I would like to identify and sell this engine and transmission that I know is for a TR-6 and is in excellent condition.
Any input is appreciated.
Guy
I dont see any pics of the Trans, OD, non OD? Location? Does the engine run, turn over?
I will get some better pictures for you. My understanding is that he engine is in very good condition. the previous owner was maticulas in his ways and always took very good care of all his cars trucks and snowmobiles. Ill gfet back to with some better pictures later today. can call if you like. + 1-713-836-1299 Guy I'm in Minnesota USA
It’s a later engine from the look of it, rough guess 1974-76? Will likely have a stamped serial number starting with CF.
Value is a tough one, certainly looks rebuildable so I would ballpark around 500 of so as a guess. You might be able to get more but unless it is physically running it is tough to gain value. A fairly fresh engine will command 2-3k and up.
Gearbox if overdrive is maybe 1k and up - no overdrive and it’s worth probably 100-200 or so.
Many Thanks
