TR4/4A Tr 4a valve seats cleaner
nicodiaz
I have run the Tr w/o filters for awhile here in Southern Cal dusty environment. Does anyone know of an effective valve seat cleaner injected directly into the air intake.
At the auto parts store no one had credible advise. Car is still running undetectably fine. Thank you for any comments.
Robert
66' Tr4a
TR3driver
Great Pumpkin - R.I.P
What makes you think the valve seats are dirty? The only "dirt" I've ever seen is where the seat is eroded away and nothing you pour down the intake is going to fix that!
N
nicodiaz
Ok. So I have no problem. But, is it not common for at least carbon build up, although perhaps not on the in-take valve?.
Robert
Oceanside
trrdster2000
Burnt exhaust valves are your worst enemy. Only after taking the head off can you get lapping compound to work a perfect surface. Most get the head reworked if there is a issue.
When getting reworked. adding hardened seats and valve guides. Triple cut grind is what I get on mine.
Wayne
Rut
Robert,
First I would buy a set of air filters! Dirty air ingested into any engine can cause premature wear of just about everything internally. If you are worried about carbon buildup and want something to help clean valves and rings you can give Seafoam a try. I've used it on a number of boat engines as well as cars and it does a pretty good job of cleaning out the 'gunk'. Just follow the directions on the can and add it to the gas when you fill up...very simple and one of the few snake oils that actually works.
Rut
TR3driver
Carbon can build up on the intake valves where the stem meets the head. But that usually is not caused by dirty air (at least not directly), but rather by oil being sucked past the valve guide. And the effect on performance is usually quite small.
All of those ads you see about "dirty valves" though, are talking about fuel deposits that can build up on some engines with early fuel injection (like Bosch Jetronic). They can spray liquid fuel directly onto the valve head, where it evaporates and leaves behind scale (kind of like hard water scale). Not normally an issue on a TR4A (and not really an issue with most cars made in the past 15 years IMO).
N
nicodiaz
You guys are great, especially taking time to respond to an apparent naive /non existent suspicion of potential problem.
Thanks.
Robert
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
dbenichou289 TR2/3/3A Valve seats Triumph 8
W exhaust valve seats Austin Healey 2
Superwrench valve seats Austin Healey 9
L Valve seats and lead [substitute]. Spridgets 18
PAUL161 Hard Valve Seats, First Year?? MG 6
J hardened valve seats Triumph 11
bluemiata90 Hardened valve seats or not Triumph 6
sim looking for 2 valve spring kippers for a 948 Spridgets 3
R Valve Drain Pipe Austin Healey 13
R T-Series Valve gap for an MGTD 1953. MG 5
6 Valve Oil Seals Spridgets 10
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
P TVR Big Valve 4.3 TVR 0
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
J MGB BRAKE VALVE ? MG 11
jehuie PCV valve explanation? British Motor Corp 5
R 3000 Heater Valve Austin Healey 4
T TR2/3/3A valve springs Triumph 15
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
T TR2/3/3A valve guides and piston clearance Triumph 6
kodpkd Valve Cover Gasket - Don't do this! Austin Healey 14
KVH General Tech Heater control valve/cable Triumph 1
G Valve Train Lubrication Austin Healey 1
KVH General Tech Valve Timing--No Marks Triumph 20
D Water Valve Connection Austin Healey 4
R TR2/3/3A Rule 9 Valve Adjustment Triumph 8
RJS General TR Lever Shock - HD Shock Valve Triumph 2
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
M TR5/TR250 Bypass valve Triumph 27
I Bugeye valve rebuild suggestions Spridgets 8
G Valve Cover Gasket Silicone Adhesive Austin Healey 5
J Oil Pressure Relief Valve Austin Healey 3
K TR2/3/3A An alternate valve adjusting sequence? Triumph 3
K TR2/3/3A Camshafts and Valve Settings Conundrum? Triumph 7
charlie74 TR6 ‘74 valve springs Triumph 0
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
M TR6 PDWA valve Triumph 6
M Ray Juncal Valve Covers Austin Healey 5
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
BillyB62 TR2/3/3A Anyone seen a valve cover like this Triumph 0
alexisrexx TR6 Oil Sludge in Valve Cover - Normal? Triumph 16
K TR2/3/3A Brake Restrictor valve? Triumph 9
Lin Heater water valve question Spridgets 2
D MGB MBG valve clearance MG 1
K TR2/3/3A Finding valve lash with cam specs? Triumph 8
A T-Series MGTD oil pump bypass valve MG 0
S Price check on TR3A valve cover Triumph Classifieds 0
H BJ8 Heater Valve/Control Tap Austin Healey 3
