af3683
My TR-3B always seems to lose quite a bit of gas when sitting for a while. I've checked and can't find any gas leaks and don't smell gas in the garage. I know that the gas tank is vented and assume that that could result in the loss of gas over the winter months. However, the gasket on the front float bowl in particular always seems to be a bit wet. I'm probably going to go ahead and change the gasket and see if that helps. Any help would be appreciated.
Also, does anyone know what the bolt size is for the cap nut on the float bowl? It seems 1/2" is too small and 9/16" is a bit too large. I can't believe that it is 17/32"? Also, should there be a washer under the bolt? Thanks.
Art
Art
