TR2/3/3A TR-3A - spare tire
midnight
I know i have seen this before - can't find it - Any suggestions on the best place to get a 5.50 x 15, for spare tire - midnight
Look for VW beetle tire, they took at 5.60x15 which is what many use.
I picked up a "compact spare" tire from a junkyard for about $15 including the wheel. Turned out the wheel didn't fit, so I had the tire mounted on an original TR3 wheel. Works great; only problem is the extra room in the spare tire well (which I fill with a rolled up cheap blanket)
Only had to use it once, but that time I drove nearly 2 hours at around 70 mph with no problems.
If you have a post 60k body, you should be able to fit a 165x15 in there. I had no trouble fitting that size in my car.
