TR2/3/3A TR-3A Rear Leaf Spring Broken
Royal_58
Out driving last week and I broke a leaf spring on the right rear. The top bar sheared about 3 to 4 inches back from the forward attach point. It broke clean and straight across and makes a heck of a racket and handling is poor.
I'm know nothing about suspension and handling but need suggestions on repairing the problem. If I can invest a few more bucks and improve handling from standard I'm willing to do that.
I'm looking at replacing both rear springs and wonder if the Moss replacement # 851-195 is adequate or is it better to upgrade to the 851-180 "competition" spring for $80 more. I do like to drive it a vigorously.
I will also be replacing the bush set in the front and rear with urethane and silent block products. What is the rear axle locator kit 674-478 about and what effect will it have on ride, handling? Is it worth $80?
Is there a better source for suspension parts? I'm shopping between TRF, Moss, and Victoria British currently.
TR3driver
Great Pumpkin - R.I.P
Well, did the stock rear suspension bottom out frequently when you were driving "vigorously"? If so, the "competition" spring (which just has a higher spring rate) might be an improvement. Or it might be that your old springs were just sagged and new stock springs would do just as well.
Stiffer springs in the rear will also decrease the roll rate, making it easier to lift a tire in hard corners.
Bottom line, I'll be ordering stock rate springs for my TR3.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]What is the rear axle locator kit 674-478 about and what effect will it have on ride, handling? Is it worth $80?
[/QUOTE]
It's basically an even firmer version of the rear bushings than the urethane. I don't have any experience with them, but my guess is that you won't see a lot of difference in either handling or ride; unless perhaps you're running wide tires that hit the fenders in really hard turns. I was having that problem on my (now wrecked) TR3A, but as near as I could tell, most of the deflection was in the springs themselves rather than in the rear bushings. And since I don't have the TR3 back to the same level of preparation yet, it hasn't been an issue. If it does, I'll probably go back to my previous plan of fabricating a Watts linkage and keep the bushings soft.
One suggestion you might consider is to disassemble the new springs and insert .005" UHMW plastic between the leaves. It substantially reduces friction between the leaves, giving both a softer ride and some improvement in handling on very rough roads.
sp53
Do not be surprised if you have to lift the rear of the body off the frame to swap out the leaf springs. The bolt towards the front is long and basically trapped between the body and the frame. It is possible to remove the bolt, but often they are rusted solid where the go through the frame. So at the end of the day, it is often better to remove the nut lift the tub and leave the bolt in place and use the old bolt. The tub comes lose a lot easier than it sounds. I have had the bolt just come right out before, and I have had the tub completely off and pounded the bolt out with a very large BFH with much effort.
TR3driver
Maybe I've just been lucky, but I've always been able to get those pins out using a length of all-thread and an assortment of spacers as a puller. Start by soaking it in PB Blaster for a week or more, then cleaning out the threads in the head of the pin with a bottoming tap. Probably best to pick up some high-tensile threaded rod
https://www.mcmaster.com/#standard-threaded-rods/=hted25
but the first time I just used ordinary rod from the local hardware store, and replaced it when the threads got to looking bad. You can also pick up some heavy "setup" washers from MMC.
Make sure your first spacer fits over both the head of the pin, and the tab on the frame that keeps the pin from turning. There isn't room to do it in one pull, so you'll have to start with a short stack of spacers, and then add more as the pin comes out.
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
Popeye TR4/4A Rear leaf spring - do I have a TR4 spring on my 4A?? Triumph 4
Popeye TR4/4A Rear leaf spring bolt torque Triumph 11
Popeye TR4/4A TR4A rear leaf spring distance piece Triumph 11
S Question regarding NOS vs New rear leaf spring bushings Austin Healey 3
Popeye TR4/4A TR4A solid axle rear leaf spring question Triumph 14
S Any recent experiences with rear leaf spring vendors? Austin Healey 31
K TR2/3/3A TR4 rear leaf spring "distance piece"? Triumph 1
L WTB - rear leaf spring, late model Sprite / Midget Spridgets 8
H rear leaf spring to chassis bushing Austin Healey 11
DornTRoriginal TR2/3/3A Rear Axle & Leaf Spring Installation Questions Triumph 3
R Rear Leaf Spring Removal Triumph 10
K TR2/3/3A TR3 Rear Leaf Spring Shackle Bushes Upgrade Triumph 14
K TR2/3/3A TR3 Rear Leaf Spring Front Pin Removal Triumph 17
Tabcon Rear leaf spring bush size? Triumph 21
tahoe healey iron bushing removal rear leaf spring Austin Healey 6
N Rear leaf spring brackets Austin Healey 9
T TR4/4A TR4 Rear Leaf Spring Mounts Triumph 6
8 Rear leaf spring Triumph 3
F new rear leaf spring disapointment... Triumph 9
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
Keith_M Bugeye rear leaf springs Spridgets 19
K TR2/3/3A New Moss Rear Leaf Springs Triumph 7
K TR2/3/3A Moss rear leaf springs? Triumph 19
Jeepster BJ8 rear leaf springs Austin Healey 2
B TR4/4A TR4 Rear Leaf - Do I need distance piece? Triumph 5
P BJ8 phase 2 rear leaf springs Austin Healey 2
D Replacing rear leaf springs ? Triumph 6
bugedd Rear leaf install Spridgets 7
H TR2/3/3A TR3- installing rear leaf springs = nightmare.... Triumph 5
tahoe healey re-arching rear leaf springs Austin Healey 27
Johnny AH 3000 BN7 rear leaf springs modifications. Austin Healey 4
B rear leaf springs Spridgets 14
prb51 Rear Traction Bars for our Leaf springs Triumph 0
malice Rear leaf swap. Triumph 8
T TR4/4A Early TR4 - Rear Leaf Springs Triumph 3
AUSMHLY Rear leaf springs Austin Healey 6
Michael Oritt BN1 rear leaf springs Austin Healey 4
S Rear Leaf Springs Austin Healey 30
bighly Replacing rear leaf springs Austin Healey 10
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
