OK-I have gotten carried away. I chromed the hood spring. I believe the spring rod should have a rubber bumper. Does anyone know of a source or has anyone found something at a hardware store they recommend?
I bought some neoprene washers from either a Lowes or Home Depot to use as a vibration isolater between the spring and mounting bracket. I also enlarged the hole in the bracket that the rod passes through so that I could insert a plastic collar for the rod to slide in.
