Does Moss still offer this? Didn't see it in recent catalogs and thought they may have dropped it when the yellow fan became NLA (as a new item).
I have used the yellow fan on a TR4 by reversing it and adding a spacer. Then I got a tropical fan for the 4 and was going to move the yellow fan to the TR3A (looked like that set-up would work) but then I found a 2nd tropical fan and the plastic fan went on the shelf.
IMO -- you should be able to find a decent tropical fan for less than that adaptor and get much improved air at idle while retaining a stock (or original option) look.
Just my opinion, but that's an awful lot of money to add the plastic fan. I forget who on this forum recommended it, but there is a BMW plastic fan that is higher efficiency and a pretty easy bolt on option without interference issues - and much much less expensive too. Or source the tropical fan option as Geo says - they don't come up often but they can be had for less than the cost of that adaptor when they are available.
Mentioning it here is a good start (that's how I found both of mine) otherwise keep an eye on eBay.
If the cooling is more important than the look I can set you up with a plastic fan & spacer. I painted the fan black so it didn't look too obvious -- in fact I would have used it on my TR3A except I found I would have had to pull the nose and radiator to mount it -- I was able to replace the stock fan with the Tropical with the radiator in place.
The fan is from a TR6, the spacer I made from a plastic (acrylic?) cutting board about 3/8" thick. I then mounted the fan backwards using the spacer. You almost have to set it up for a specific car as I have seen some where the fan could be used right way 'round, others where it was reversed for clearance.
RonR
I was going to use the Moss plastic fan and it took me years to convince myself to buy one. I wanted to keep the car period. (Still using a generator too). When I went to our local Triumph guy to get a fan he suggested using a GT6 fan. It is metal like the 3's fan and has a larger pitch and 5 blades. Best thing I ever did! Never a problem with overheating and no one has ever noticed even being judged in a car show.
Wouldn't mounting a fan backwards push air from the enginge compartment through the radiator and out the grill? Or does a TR6 engine rotate the opposite way oas a TR3?
Jedi, I have found a GT6 fan on ebay but it is an 8-blade yellow plastic fan. Does anyone know if this is a simple bolt-on replacement to the origina, TR3 fan?
Since a fan blade is not in a flat plane, like a nut, but rather pitched (or angled) to direct air a single direction depending on the rotation of the fan, wouldn't reversing the fan be no different than changing the direction on a ceiling fan to direct air down from the ceiling instead of up towards the celiling?
I finally got it. The fan blades aer symetrical along the centerline of their lineal axis, making the air flow the same as long as the rotational direction is the same.
