TR2/3/3A TR-3A Compresson check hot vs cold
midnight
This morning a ran a compresson check on my 1959 TR-3A - COLD, I was 120# on all four - HOT, I was 100# on all four - I don't understand - I thought it would be exactly the opposite - The motor has 22,000 miles on it - ????? Mid- Night
TomMull
The good news is that your compression is consistent although very slightly on the low side. The gauges are not always that accurate and could account for the very slightly low numbers. Certainly no reason for concern at this point.
As for the hot and cold readings, cold oil might provide a better seal than hot oil, outweighing the effect of expansion of the hot metal. I've never done mine hot.
Tom
CJD
Too many variables to know. Is the starter up to speed hot? Throttle and diaphragm blocked open on both tries? Valves set loose enough? Gage seal consistent? Battery charged fully and in good shape? I general I would expect the pressure to be the same or slightly higher too when hot, but there are a lot of other variables that can account for it. In the end...like Tom says, if it checks by the book cold, don't worry about the hot numbers.
TFB
I would be concerned the valves were to tight.You could pull the cover while hot and just make sure there is some wiggle at tdc.
Tom
M
midnight
Thanks for the comments - everything is good - battery, starter, valves, ect. - I just thought the hot cold differental was odd - the motor only has 20,000 miles on it - it runs good - like every TR I have been around it has piston slap that goes away once the motor is warm - but, sense I am anal, I am changing out the piston and sleves this weekend - boredom - midnight
TomMull
Certainly will do no harm, other than to your checking account, and you might want to check and lap the valves while you've got the head off, although that will add another couple of hours to the job.
Tom
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
AngliaGT In Check,VA Today Spotted 2
Rob Glasgow Check Strap Assembly Austin Healey 5
F TR2/3/3A Check strap alignment Triumph 11
T General Tech Once again, check the easy stuff Triumph 2
AngliaGT Got Lucky Today - CHECK THOSE BOLTS! Spridgets 6
S Price check on TR3A valve cover Triumph Classifieds 0
Twit TR4/4A early tr4 check straps Triumph 4
F Check for matching nrs Austin Healey MK2 Austin Healey 3
Lukens For Sale Check out this tr3 project for sale... A real treasure trove Triumph Classifieds 0
V TR2/3/3A Vertical link check Triumph 2
R TR4/4A Door check straps Triumph 7
68_sprite Check the August Oprah Magazine Austin Healey 5
HighAltitudeTR3 TR2/3/3A Door Check Assembly Triumph 19
S Door Check Strap Austin Healey 5
AngliaGT Why You Should Double - Check Your Parts When You Receive them. Spridgets 2
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
AngliaGT Anyone in Charlotte,NC That Could Check Out a Truck for Me? Other Cars 0
C Rough Idle - What to check? Austin Healey 12
KVH TR4/4A Door Check Straps Triumph 11
S Overdrive Wiring Check Austin Healey 12
Michael Oritt Door check installation Austin Healey 7
P TR2/3/3A TR3 turn signal and horn control wiring check Triumph 4
warwick-steve Brake drum check and lubrication Austin Healey 9
Rut Sanity check! Spridgets 2
1 Price check on an original 1957 100-6 BN4? Austin Healey 29
Mickey Richaud General Tech Always Check the Fundamentals MG 10
F Check out this new restoration diary - BT7 - very brave! Austin Healey 7
D TR2/3/3A Door check bracket? Triumph 7
C Brake issue on my 1969 XKE - what to check first? Jaguar 14
Martinld123 Compression check 1956 BN2 Austin Healey 7
M BN1 door check replacement Austin Healey 9
R Last minute check before engine install Austin Healey 26
Boink Check out some Sprite shots at the Portland ABFM... Spridgets 1
Rut TR4/4A Get out your check books! Triumph 10
Gerald_Gordon TR4/4A Failure of new door-check strap on an early 1961 TR4 Triumph 6
S How to check Dwell on a MK I 3000? Austin Healey 27
K TR2/3/3A Re: TR3 Bump stops and check straps. Triumph 18
PatGalvin TR2/3/3A vacuum leaks? How to check Triumph 9
jlaird Check Spam folder Spridgets 3
I TR6 Got in a wreck - need some help on who to take it to and what to check Triumph 48
HealeyDave Door Check Friction Adjustment Austin Healey 12
RedTR3 TR2/3/3A How to check for cylinder-to-cylinder head gasket leak Triumph 7
sundown TR6 1973 TR6 door check straps Triumph 3
DanLewis Weber 40DCOE - Does it need a check valve in the fuel supply line? Spridgets 4
drooartz General Tech Check those brake hoses! MG 11
sundown TR6 Door check strap Triumph 3
Tinkerman TR2/3/3A Continuity Check on Tranny Lock out switches Triumph 2
