I have just helped a friend rebuild his carbs on a TR 3, which has a Cramer electronic ignition. As far as we can tell, there is nothing to adjust with electronic ignition.
The car pops, or misfires, I guess, sometimes upon acceleration.
We need help in determining the correct setting for the timing. The service manual says 4 degrees BTDC but does not say if this is static or at some rpm. The service manual also does not list a maximum vacuum advance. I know some British car owners prefer to set the timing for the maximum advance and let the timing at idle be whatever it is.
Finally, the gas pedal will not allow the butterflies to open completely when the gas pedal bottoms out on the stop bolt. Will changing the length of the throttle linkage just below the point of attachment to the front carb throttle shaft adjust this? If so, should it be lengthened or shortened?
Thanks,
Ron Ray
Thanks,
Ron Ray
