Hello fellow Triumphers,
I have a 57 TR-3 smallmouth which should have the two side latches with the middle key lock. I have a boot which is from a later car, but I also have a correct boot that is pretty rusted, however it does have the side latches that I could remove and weld to my newr boot. Is the older and newer boot dimensionally the same? If so I will drill out the newer boot and convert it.
Thanks,
Captainde
Thanks,
Captainde
