TR 3/4 rear crank Viton seal kit
MadMarx
Hi,
I would like to announce that from the simple Viton seal a whole kit is created around it.
That should make installation more easy instead of turning the stock seal to fit.
The centering tool is made to the corrected measures instead of the workshop manual suggestions which lead to a leaking engine.
Cheers
Chris
Hi Chris-
I am using your seal in two other engines at the moment and I'm very pleased. With your kit, have you eliminated the scroll section on the aluminum housing?
How will you be marketing it?
Randy
