angelfj1
<span style="font-weight: bold">This is related to the ongoing discussion regarding Classic Gold MC's.
</span>
<span style="text-decoration: underline"><span style="font-weight: bold">There is NO direct reference made to a particular vendor in this post.</span></span>
We received two after market master cylinders from a major US supplier. These happen to be manufactured in India.
The purpose was to disassemble the MC and compare the internal parts to both original and CG cylinders. Also, we wanted to post a few accurate photos which indicate the excellent authenticity of the CG MC compared to the original Girling.
The first series of photos are the original Girling MC taken off TS58476 LO.
The next series of photos show the after-market MC's. Note the obvious differences in the casting.
Finally we have comparison photos showing the external difference between the after-market Girling replacement and the CG MC's.
If you look at the internal parts from the after-market Girling replacement, you will see that they look identical to the original Girling units. One exception that can not be seen in the photograph - the non-return valve spring is the coil type and not the wave type.
The next step will be to carefully measure the internal parts and compare them to the original Girling and CG M/C's. Further, we plan to install the after-market Girling parts into a CG M/C and test it (probably clutch).
Please stay tuned for additional reports.
Cheers.
</span>
Cheers.
