TR5/TR250 TR 250 windscreen corners
TonyPanchot
Hi all,
Have a question; I am curious as to the finish at the point where the leading edge of the door windows (when up) meet with the windscreen the new seals I installed have are open bit of an oval and did not know if this was standard or I should fill it with a sealer
any thoughts??
Thx,
Tony
how do I post a pic of the issue at hand ???
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]how do I post a pic of the issue at hand ???[/QUOTE]
When you post or reply go to "File Manager" at the bottom of the page. It will allow you to select a JPEG file from your computer, however the image must be 150 KB or less.
Otherwise, post the image on one of the infinite sites on the web which support and allow you to, then use the "create a link" icon above where you type, and give the URL.
well my camera lowest setting is vga an that produces a pic size of 1.4
.4 too big to post
tomorrow I will shoot with the blackberry and that should work
just trying to get things just so for the Easter STL car show and the Triumph VS
MG thingie
we must overcome
