Hi Guest!
TR4 said:I am an extreme novice mechanic so I have to ask, would it be possible for me to change a head gasket on the side of the road or did the kit include one so you could give it to a shop to change out?
amcboy said:Weeeel, a true manly-man would knaw out of bark from a local tree and then use only his Leatherman (TM)(C)(R)(RSVP) to extract the offending part and insert the new "organic" gasket.
Andrew Mace said:My 1st edition TR250 Spare Parts Catalogue doesn't list it, but my TR4A SPC lists the following in the "Continental Touring Kit" (probably similar):
2 each exhaust and intake valves and inner and outer springs
Sadly, the Spare Parts Catalogues do not elaborate on the contents of the "kit" for Spitfire, but I can confirm that 516248 is for the Mk3 Spitfire. Presumably, it would have the same items as I listed earlier in this thread as would be in the TR4 kit.Randy Forbes said:I just had someone offer me two (2) of the following items:
<span style="font-weight: bold">Triumph "for loan only" "Continental Touring Kit Emergency Kit Number 516248 For the Spitfire". The manufacturer seems to be "Stanpart".</span>
Thank you Andrew, sounds pretty comprehensive, with any luck, maybe there'll be a parts list included with the box.Andrew Mace said:Sadly, the Spare Parts Catalogues do not elaborate on the contents of the "kit" for Spitfire, but I can confirm that 516248 is for the Mk3 Spitfire. Presumably, it would have the same items as I listed earlier in this thread as would be in the TR4 kit.Randy Forbes said:I just had someone offer me two (2) of the following items:
