TR5/TR250 TR-250 Radiator Shroud
arbs_53
In the next couple of weeks, I will be installing my freshly re-built engine into my little six-pot and I would like to install a radiator shroud to help in cooling the engine. Years ago I ordered the two flat pieces of air deflectors that are supposedly what was supplied from the factory for the 250, but I couldn't figure out how to attached them. I'm also missing the clips that are needed to finish the job. I would prefer to use a real shroud; one that fits between the back of the grille and the radiator. I was wondering if one from a TR4A would work. Does anyone have any suggestions?
Dave
A
arbs_53
That's just what I was looking for. Thanks, Geo.
Alan_Myers
Hi,
If originality is important, you'll want the fiberboard item shown at the above link.
If durability is more important, some of the vendors offer a black plastic version that holds up better (VB, I'm pretty sure, and maybe Moss and TRF, too). It is actually a TR250/TR5/TR6 style shroud, so should be a good fit for your car. But it can be fitted to TR4/4A with a little tweaking. It doesn't include the two side pieces #94 shown at the above link and cost a bit more than the fiberboard version even when I bought one about 5 years ago. And, I had to elongate the mounting holes because they were drilled off center and shifted the whole thing to one side.
To use it on TR4/4A, it helps to reinforce it with a strip of 1/8x3/4" aluminum riveted inside, to encourage it to bow upward for a better match to the earlier radiator shape. And something is needed to extend the top and sides about 3 inches to fit snugly up to the radiator. I'm using reinforced rubber sheeting. Even with modifications, it's cheaper and easier than fabricating one out of aluminum.
Those fiber board shrouds seem like a silly, throwaway item. But most TRs of all years will overheat if driven without one in place.
Cheers!
Alan
RobT
I installed the plastic shroud from VB on my TR250, and it noticably improved cooling. The mounting holes did not match up very well and had to cut a slot for the oil cooler hoses, but otherwise was pretty straight forward. That, combined with a 14" thermostatic fan, keeps things cool.
Rob.
A
arbs_53
Great information guys. I always had problems with the engine temperature while in traffic, and my anxiety level would rise along with the needle as it crept nearer and nearer to the redline. Part of the problem might have been gunk in the water jackets (I once had to use a small screwdriver to dig some of it out to get the water to drain out of the block). But I just had the engine re-built and now everything should be clean. But I thought the shroud would be good insurance, instead of those two pieces of fiber-board, and from what I've read, essential. /ubbthreads/images/graemlins/cheers.gifThanks.
pbraun For Sale Triumph TR 250 Project Triumph Classifieds 0
BritBite Stiff steering effort Daimler SP-250 Other British Cars 11
V Wanted TR-250 in excellent condition Triumph Classifieds 14
T Wanted TR 250 Seats Triumph Classifieds 5
E TR6 measurements of a Snugtop hardtop for 250/6 Triumph 2
T For Sale Triumph tr6 early tonneau cover - $250.00 Triumph Classifieds 0
T TR5/TR250 250 Sway Bar Link Triumph 0
mrv8q TR5/TR250 Red 250 for Christmas morning! Triumph 10
T TR5/TR250 TR-250 Guages Triumph 4
T TR5/TR250 Amazing TR-250 Triumph 4
T TR5/TR250 TR-250 Production Numbers Triumph 1
T TR5/TR250 TR-250 Tire Size Triumph 6
M TR4/4A TR4A & 250 front bumper guards Triumph 5
Marvin Gruber TR5/TR250 TR 250 horns Triumph 3
D TR4/4A TR-250 seat covers on TR-4 seats Triumph 3
NutmegCT Daimler V8/250 or Jaguar MkI/MkII wanted. Other British Cars 0
NutmegCT Daimler V8/250 or Jaguar MkI/MkII wanted. TVR 0
NutmegCT Off Topic Daimler V8/250 or Jaguar MkI/MkII wanted. Triumph 1
NutmegCT Daimler V8/250 or Jaguar MkI/MkII wanted. Sunbeam (Rootes) 1
NutmegCT Daimlere V8/250 or Jaguar MkI/MkII wanted. Spridgets 7
NutmegCT Daimler V8/250 or Jaguar MkI/MkII wanted. Rover / Land Rover 0
NutmegCT Daimler V8/250 or Jaguar MkI/MkII wanted. British Motor Corp 0
NutmegCT Off Topic Daimler V8/250 or Jaguar MkI/MkII wanted. MG 17
NutmegCT Daimler V8/250 or Jaguar MkI/MkII wanted. Lotus 2
NutmegCT Daimler V8/250 or Jaguar MkI/MkII wanted. Jaguar 6
NutmegCT Daimler V8/250 or Jaguar MkI/MkII wanted Austin Healey 0
NutmegCT Daimler 250? Jaguar 0
H TR4/4A Triumph 250-K by Pete Brock--anybody recall how much Brock advertised it for? Triumph 1
M TR6 TR-250 CC engine runs great, then nada, wait > 2 days, then runs great again, repeat Triumph 7
HerronScott TR4/4A TR 4/4A/250 Hard Top/Surrey Top on eBay Triumph 14
Nunyas John von Neumann's Ferrari 625/250 TRC Other Cars 0
Nunyas New Petrolicious vid: Ferrari 250 GTO Other Cars 2
tinman58 TR5/TR250 TR 250 Grill Triumph 14
tinman58 TR5/TR250 250 wheels [rims] Triumph 23
DNK TR4/4A TR4 & 5 owners and 250 Triumph 19
DMShuman TR5/TR250 TR-250 Vacuum advance module.... Triumph 5
tinman58 TR5/TR250 250 gettin there Triumph 4
C Daimler SP 250 - Pedal Rubber/Pads + other bits Other British Cars 6
tr6nitjulius TR6 TR6/250 & Healeys Drive 'em! Triumph 0
PatGalvin TR5/TR250 TR-250 Buyers Guide Triumph 12
NutmegCT 1971 Mercedes-Benz 250 Spotted 1
tinman58 TR5/TR250 TR 250 Steering rack ? Triumph 2
tinman58 TR5/TR250 TR 250 head? Triumph 4
tinman58 TR5/TR250 TR 250 "While I am there" Triumph 23
tinman58 TR5/TR250 Tr 250 A/C Triumph 9
EricG Tiger/Daimler SP 250 Comparison Test Sunbeam (Rootes) 1
glemon TR5/TR250 Lowering TR4A/250/6 in the front Triumph 13
TonyPanchot TR5/TR250 TR 250 Hub Cap Triumph 12
tr6nitjulius TR5/TR250 FYI: Ford Blue 250/6 Triumph 12
mrv8q TR5/TR250 TR 250 Silver Springs. MD Triumph 0
