RobT
Hi Ya'all
Been a while since I posted here, but things have been pretty quiet for me on the Triumph front.
Over the winter I did get around to pulling the head on the TR250. It started off as just popping of the exhaust manifold for a tidy up, but noticed some old build-up from what looked like coolant seeping from the side of the head gasket. So off with his head!
All looks pretty clean and wear-free inside, so did some de-coking and lapped in the valves for reassembly. With the head off I checked the compression ratio using Richard Good's excellent guide: https://www.goodparts.com/tech_docs/TR6_Compression_Ratio.html
I measured both the overall thickness of the head, and the volume of the combustion chamber and get a compression ratio of 10:4:1 with both methods.
My question is: Is this too high? And if so, how should I drop it? Use two head gaskets?
Before the rebuild, I was getting occasional pinging, and using an octane booster generally helped, but wondering if, with regular 93 octane petrol, 10.4 is just too high a compression ratio for these engines. Has anyone else had experience running this high a ratio?
TIA,
Rob.
TIA,
Rob.
