Toyota Brake Caliper conversion ?
no not from Ted either but i do like his braided hose idea; the only trouble with the braided lines as i see them is the extra adapter the screws in, rather than being attached directly. imo, it's an(other) opportunity for leaks.
it looks like (do not know for a fact) he uses an std. AN3 (jic) to AN3 hose and then an AN3 to metric M-M adapter. AN3 has a 3/16" UNF thread that will fit the TR but AN3 is 37degrees and TR uses a 42 degreee inverted flare fitting. to solve the flare angle diff, pegasus racing sells a little copper flare crush tip for about .70.
anyway, i'll keep looking.
TRF has the late model bolts with the metric shank that will bolt up the toyota calipers, current price is $5.75 each-- part number (not in their regular catolog) is 158668. Victoria British wants $8.95 each
those (hard lines) are the ones I thought macysgarage sold. thanks for finding them, it was driving me crazy searching for the line. duh ... trparts.com
when I fab'ed my own, I tried this design and found that at full lock the "hoop part" would interfere with my coil springs, so I bent the hoop up 90 degrees. it was a much harder bend since these lines are so small but it works. I guess it's another reason to consider flexible SS lines but these would have to be tied off to prevent fouling on the suspension too.
