vettedog72
Towing a TR6 can be a problem. Perhaps you have all ready discovered it can be done with U HALL; but with only an auto transporter. The U HALL “car dolly” will not do it. There are 2 types of car dolly’s but neither will accommodate a TR6. One type dolly has slide out ramps and allows the car to get up in position but then the ramp can not be raised enough to slide back in because they will hit the rocker bottoms. The other type of dolly simply will not allow the air dam to clear the ramp and appears that the fixed ramp would be on the bottom of the rockers if you could get it into position. The auto transporter is the only thing that will work. By the way, UHALL will not allow Ford Explorers to tow any car.
For the record, my TR6 has never required towing since 1978; it has proven very, very reliable with only nuisances being a problem /ubbthreads/images/graemlins/yesnod.gif
