longbridgehealey
I know this has been discussed before, but has anybody successfully towed a 100-6 with a U-haul open car trailer? Wheel width being the issue, of course.
Thanks!
Thanks!
I was going to say that I used a U-Haul trailer to move a 100/6...
Remember to position the car on the trailer so you have a positive net weight on the hitch. You don't need much but you don't want the car centered where the trailer "seems balanced". If it seems balanced the trailer hitch will keep trying to jump off of your hitch as the trailer will keep porpoising. And deffinately don't let the weight favor the back end of the trailer. As as an example of what happens with a seemingly balanced trailer or one with the weight to the rear, when I towed the Midget to Mass. after headed back with an empty trailer I had only gotten on the Interstate for a few miles and realized that the trailer was porpoising enough to make things unsafe. I had to pull off and take the 3 plywood sheets that I had fastened to the trailer decking and stack them at the front of the trailer to get the weight on the hitch. Fortunately I had some large "C" clamps and used them to hold the plywood in place. After that the trailer rode beautifully all the way back to Pa. Dave.
