General Tech Towing a Triumph
KVH
Most towing companies where I live use flat bed trucks and say that for small low to the ground vehicles like LBCs, they just wrap their nylon straps around the front control, arms and pull the vehicle up on the flatbed.
Is that acceptable?
My tow on roll off the driver had to use blocking to keep the rear from dragging.Luckily he took his time,and I believe he hooked the lower control arms.
tom
Sounds good. I just thought with a careful jack they could wrap around the front frame cross-brace and pull by the frame, but I suppose the bolts holding the control arms on will do the job for a mere “pull up.”
