Touch-up paint over original factory paint
tdskip
This is for the '68 TR4A, and I'm wondering about how modern touch-up paint from Paint-Scratch or similar will react with the original factory paint. Any suggestions / lessons learned to pass along?
Geo Hahn
Never have had any problem with a reaction of any kind -- color-matching is, of course, sometimes a challenge with 40+ year-old paint.
I got my paints from Tower Paint in Oshkosh which offer a choice of enamel or lacquer.
Geo Hahn
Yes they did. I can't judge the Signal Red with complete certainty as I have a respray on the car though it and the spray can from Tower were close.
The Triumph Racing Green (aka Conifer) was very accurate.
MGTF1250Dave
Aloha Skip,
The local distributor for Dupont auto paint here in Honolulu offers a service to make a 16 oz spray can of single stage paint for about $12 in a custom color. You will need to provide a manufacturer's color code or they will bring a color match device out their parking lot to match your car. I would think the LA area would have a similar service available at an auto body paint store.
I was able to get rattle cans of paint that matched both my TR3 and my wife's Mazda very well.
Britishautobody
I have to agree the paint shouldn't react in a negative way from a simple touch up. Some paints when fresh react to top coating adversely. Getting a close match is where the trouble lies, some colors tend to dry darker especially reds. I would try to make a touch up kit from the brand of paint that is on your car if possible. Otherwise I would go to a pro shop and ask the painter to custom make something close from what you have to work with for the best possible result.
DougF
A customer showed me a little trick for prepping stone chips that have rusted or scratches or other small areas that need sanding.
With the desired grit paper, using a paper punch, punch out several paper dots. Apply one to the eraser tip of a pencil with an adhesive. I use the 3M adhesive for sand paper.
It gives you great contol in small areas and little concern of taking too much paint surface away.
Rut MGB Pale Primrose touch up paint MG 4
AH67 General TR Touch up Paint 11/PAA Black Triumph 2
Marla TR4/4A Touch up paint Triumph 3
M TR2/3/3A Where can I get British Racing Green, 1958 Triumph tr3a touch up paint in the USA? Triumph 3
B MGB Touch up Paint? MG 2
F Source for Touch Up Paint for Primrose Yellow? Triumph 3
RAC68 Old English White Touch-up Paint Austin Healey 8
G MG touch up paint supplier finally! Spridgets 14
N Touch up paint!!? Spridgets 8
R Touch up paint help please Triumph 11
6 Touch Up Paint Q's Austin Healey 6
T Paint Touch Up Jaguar 4
J touch up paint, . dry time affect on color Austin Healey 11
NutmegCT Paint touch-up - Duplicolor equivalents? Restoration & Tools 11
S Touch-Up Paint Triumph 5
R Source for spray cans of touch-up paint? Triumph 12
Musicman Touch-up Paint Triumph 8
78MGB Touch Up Paint MG 3
R TR4/4A Carburettor is French for DON'T TOUCH! Triumph 2
K TR2/3/3A Front brake rotors hot to the touch...... Triumph 6
L Ice Blue [BU2] touch up pen Austin Healey 5
M For Sale 2006 Aston Martin DB9 - Get in Touch with your Inner James Bond Other British Classifieds 2
glemon Primer Touch up Restoration & Tools 4
F DON'T TOUCH THAT HEATER VALVE- a repair if you did Austin Healey 19
AUSMHLY Does your steering wheel touch your legs? Austin Healey 7
tosoutherncars Driver's floor touch-up Spridgets 27
kcbugeye1275 Getting back in touch Spridgets 6
Steve P. It pays to keep in touch with friends... MG 4
A Paint Color Codes Austin Healey 0
E TR6 Topaz (84) Paint. 84. Triumph 3
B Cove Paint Color Ideas Austin Healey 10
L Removing Master Cylinder Without Paint Damage Austin Healey 27
1 TR2/3/3A British Racing Green Paint Codes Triumph 6
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
vpanza Wanted Salvado blue paint sample Triumph Classifieds 8
B 1977 Midget - Sandglow Paint Restoration & Tools 3
B TR6 Help with color and color code / paint recommendation Triumph 4
HealeyPassion Finally, paint on chassis Austin Healey 17
Fanch00 Does it make sense to just paint the panels? Austin Healey 3
K TR6 Need help with Mimosa Yellow Paint Triumph 1
C Alternative to Moss's BMC Green Engine Paint Austin Healey 10
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
Bayless A Sprite gets some paint finally Spridgets 2
D Body/Paint Shop Recommendations Austin Healey 1
BoyRacer Rattle can Healey Blue paint Austin Healey 2
Bayless More Paint Other British Cars 3
algot1901 Paint Other British Cars 15
BobHaskell "paint" thickness tester? Restoration & Tools 9
algot1901 1950 Ford Prefect Paint Other British Cars 5
Joel Lester TR2/3/3A DIY paint job? vs leave it to the professionals? Triumph 27
