Thanks to Paul in Rhode Island for steering me on this one....
I bought my TR6 in '84 with 19k miles on the clock and it always had a small leak from the rear crank; one certainly not worth breaking down to fix. There was also a small pool of oil at the very back of the head, which collected on the block at the bellhousing. While I cleaned it from time to time, I never really paid much attention to this leak...it was so, small!
Last summer, after a dialogue here, I traded to 10-40 oil from 20-50, and at the same time removed the remaining pollution equipment. The pool of oil on the block seemed to increase as a result which, at the time, I attributed to the engine hoisting screws. That turned out not to be the case. Two weeks ago, after much searching, I finally saw a leak coming from the very back of the head.
Figuring "why not?", and one step away from replacing the head gasket, I retorqued the head. Indeed, some of the nuts seemed a bit, er, loose. Afterwards, a test drive revealed,'lo and behold, that not only did the head leak vanish, but the leak at the crank as well - which indicates it wasn't a crank leak at all over all this time, but a slow drip from the head coming down the side of the block.
I feel very lucky for such an easy fix. It usually turns out for the worse. But the once again moral of the story is: check the obvious. So if any of you have a rear crank leak, with some oil collecting behind the head, torque the head!!
PS - Indeed, the leak was exacerbated by the lighter oil. But I still stand by the cold start benefits associated with same for less frequently driven, cold weather cars.
