Torque settings and extensions
amcboy said:
Bob, now that is valuable advice!
Ever compare types of TQ wrenches?
Scaaary sometimes.
Advice: Get yours checked/calibrated!
Just my .02
I have found that over nearly two decades, Snap-On TQ series torque wrenches are either dead on, or completely screwed up. Usually the screwed up ones were misused in a BIG way. When I retired I kept two TQ units and completely trust them.
Bob Buxbaum said:
Frankly, given the allowable tolerances of a torque wrenches, one should be more concerned with the quality and accuracy of the torque tool you own than a minuscule error that could be created by an extension.
/bcforum/images/%%GRAEMLIN_URL%%/iagree.gif
Bob Buxbaum said:
.... An extension WILL absorb power from an impact tool, but not a torque wrench. ....
The extension doesn’t know what it’s connected too. It absorbs power either way. It doesn’t affect the torque you apply with a torque wrench because you compensate for it.
When using a tongue wrench you deflect it until you reach the desired force. The flexing of the extension makes you deflect the whole thing a little farther. But since you’re concentrating on getting a certain reading and not on deflecting it some specific angle you don’t care or notice that you had to move a bit farther.
The impact tool is applying a certain amount of energy. Dissipating the same energy over a larger deflection angle reduces the amount of force created.
PC.
