letemglow said:Thank you Greg. Great Forum here...
I think I need to more precisely describe. I meant to say the gigantic 2 3/16" hub nut that holds the hub bearing to the axle stub. Its torque must be quite substantial I's assume.
Well how about 6.93 kg.m-
However, in this case the size of the nut does not influence the torque specification of the fastener.-----Keoke
Cheers Dieter
letemglow said:Great replies, thanks mates.
From the info that Bob and Keoke gave I understand now that the hub bearing nut indeed doesn't need to hold a lot and thus only moderate torquing is needed. Will go with 50 ft-lbs. then. I have recently bought a proper 2-3/16" socket - cost a fortune - so tightening will be a cakewalk.
Cheers Dieter
Bob_Spidell said:On this topic (sort of): I've wondered about the locking tab washers. Since they're (apparently) made of mild steel they will compress some under pressure. I wonder if some of the tension on the bolt/nut will be reduced as the metal compresses--partially defeating the purpose of torquing/tensioning the bolt/nut--or, is the metal fully compressed on tightening, so there's no problem?
Bob_Spidell said:I've wondered about these locking washers (mainly because it's hard/impossible to find some of them). I've never seen them used anywhere on aircraft--including engines--on which it's fairly important that things don't come apart. On aircraft, everything of importance--pretty much everything--is safety wired or cottered. I would prefer that critical fasteners be safety wired; I presume they used these locking tab washers because they were quicker and easier to use on an assembly line.
C'mon, hours? I know, you're really just trying the "play up" the socket's value :wink:BlueRidge1 said:In support of Andys post I had a post back in 11/16/06 concerning the 8 sided nut and torque specifications.
The post was number 214661 if anyone would like to reference it. The link that Andy posted is the same link that Dave Russell posted back in 06 and Dave supported the idea of a torque setting of 150 lbs. I do remember following that advise and also that I had to borrow a torque wrench from my brother because mine would not work on the left hand threaded nut.<span style="font-weight: bold">I also fabricated my own 8 sided socket on a milling machine which took me several hours to make.</span> If anyone would like to use it pm me I can send it to you if you will send it back in a timely manner.
Bob
