Top materials and makers?
Coyote1
I'm at the point in my restoration that I need a top. I find several makers, materials and prices to choose from. Can you give me your thoughts on the best bang for the bucks? Any maker or material that I should avoid?
I have always been satisfied with the Robbins vinyl tops and tonneaus for an affordable solution. I also have a (white) top and tonneau out of the 'Everflex' material -- pricier but has a nice look and feel to it.
I don't know if all TR6 tops have a zip out rear window, but if this is not standard then it is IMO an option worth paying more for.
I believe I have a Robbins Vinyl top on mine (it was on when I bought the car 9 years ago). I like it just fine though it rarely gets used. When you try and put it up when it's cold it takes Herculean strength to fasten it. I have the reflective stripe which I like a lot. Some tops don't have that so that might be a factor to consider. It also has the zip-out rear window which is nice. However, my zipper is all discombobulated so I can't zip the window up at all. Don't know if that is a common problem or not.
Just a suggestion... Why don't you contact someone who makes the tops and request a couple of samples, this way you can decide before you place your order. I have what is referred to as Deluxe Mohair Canvas (DMC). I like the canvas look and it is not affected by the cold like vinyl is.
Here's a company in the UK that I'm sure would send you some small material samples to see and feel the difference.
Note: I only know of this company but have never dealt with them.
I know Robbins seems to be the most popular but it cost more and they all seem to offer the the same materials. I guess my biggest concerns are getting a top that fits and will hold up. I don't think I will use the top very often so why spend more on something that is hidden under the boot. Are there advantages to one over another?
Coyote1 said:
...I don't think I will use the top very often so why spend more on something that is hidden under the boot...
In that case price may be your main issue -- I have never had a bad top or one that couldn't be made to fit from any of the usual vendors.
About the only action my top sees is on long multi-day trips when my wife is along, then the top is nice for sun protection. That is why I like the zip-out window.
