MTribe
Just finished a TR6 engine rebuild and have about 100 miles on the car.
Engine is leaking quite a bit. Looks like oil, but doesn't smell like it, yet doesn't look like coolant either. If anything, it has the consistency of coolant yet smells like permatex gasket compound! Used hylomar throughout, except for non-hardening permatex on the front engine plate gasket.
Anyhow, I've driven the car a few times to get it to leak, and have been unsuccessful with my post-drive analysis. Best I can tell, the leak is coming from between the front of the oil pan and the timing cover. So maybe the sealing block? (just ordered the steel one, btw, in case that's it) I meticulously sealed everything, so maybe engine pressure's building up without proper venting as I saw in another thread?
Since helping me track it down on that spotty info would be way too much to ask, here are my questions:
- What are the Top 3 most common TR6 engine leaks?
- What method do you recommend using to track them down? (Drive and look, dyes, engine running with car jacked up, etc)
Thank you in advance for any help you can provide!
Best,
Steve
Best,
Steve
