MGB Too late to turn back now. 67 MGB
bob67bgt
I drove my red 67 MGb yesterday and it was working great. Today I thought I would try to clean it up a bit. The engine front and rear seals drip a bit and the trans needs a 2nd gear syncro and layshaft. I was just going to do the engine bay but what the heck. I have the new interior sitting here and want the car painted before it goes in. This should keep me busy till spring. I'll post a few pics as I get cracking on this one. Bob
14dna
Bob; Do you always have to be busy?
Don't get me wrong, the work you turn out is second to none, but now you're tearing into your daily drivers.
Well just keep those photos coming, it does help the winter pass.
Dave :savewave:
drooartz
Wow! Not a bad day's work.
GaryBeu
Banned
Yikes!!! When your car needs work, you REALLY get with it!
Platinum
He's an animal. :jester:
davester
Wow! I'm the kind of person who could spend all day contemplating whether or not to do a valve adjustment. In the meantime you'd have your MG stripped, set onto a rotisserie and primed for finish coat.
Deleted member 8987
BTW, Bob.....if you can't find your glasses...they are on top of the dash, just above the glovebox...
AngliaGT
Easy to take apart,but hard to put back together.
I have a '78 Datsun B210 that's been in the garage for
over three years - & is supposed to be a "daily driver".
I really envy your skills!
- Doug
Bruce74B
Geez, I have trouble finding time to tighten my alternator belt to see if I can keep the iggy light off...or raise the top for the winter...or to get the tank topped off with gas and stabile.
B
bob67bgt
Camshaft, Going red with black leather/red piping. Hunting glasses is a full time job for me. I guess i'll take the doors apart and the rear chrome off today. Lynda has a doctor appointment later today so it will be a short day for me. More pics later. Bob
B
bob67bgt
Day 2 is in the books! The inner body area is blasted and the dash, etc is out. Tomorrow will be getting the sand out and sanding the blasted areas. It will not look like it changed even though another day will be spent on the project. Bob
tony barnhill
Great Pumpkin - R.I.P
Bob - were it somebody else who got overcome by the "might as well's", I'd believe that first post.....but, knowing you.......
B
bob67bgt
Bill, I have a 5 horse 2 stage compressor just for blasting and another 5 horse 80 gallon 2 stage for painting and other shop work. Tony, I was just going to clean and paint the engine bay. Once the first bolt came out it was on!This one should go quick as long as i keep at it.
Platinum
And it appears to be a remarkably sound car to start with!! Very nice! :thumbsup:
davester
OK, now I know that you are only doing this to make the rest of us feel bad. While you were doing all that I did a bit more cogitating on whether or not to adjust the valves and also thought about how to deal with all the play in the front suspension. I'm exhausted.
Platinum
WIth ya, Dave. I had t' go out an' stare STERNLY at th' B for a while...
I need a nap now.
billspit
I have a 4HP CH compressor and a siphon blaster. The compressor will barely handle the blaster if I have a new nozzle in it. Let the nozzle wear and its hopeless. I really need to get a pressure fed blaster.
I love sandblasting!
B
bob67bgt
My blasting compressor is about wore out. I have a pressure blaster and I have to wait for it to catch up. Now day 3 is winding down. I was just going to have a easy day and remove sand and scuff the blasted areas. I started to do that and changed plans about a hour into it. I removed most of the paint from the car and did 2 rust repairs. Here is what it looks like now. Bob
Keoke SEE it is never too late Austin Healey 3
J TR4/4A Exhaust a tad too loud... Triumph 6
jfarris Message too long error FORUM Navigation Questions 8
mctriumph TR2/3/3A The concept of too many Triumph 8
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
KVH General Tech Flywheel Bolts Too Long For Main Seal Triumph 13
R For Sale Conundrum - Too Many Bugeyes Spridgets Classified 1
Popeye TR4/4A Slave rod seems too long but is not Triumph 7
K TR2/3/3A Front wheel bearing felt seals too large? Triumph 9
M TR6 76 TR6 Brakes too tight Triumph 10
B TR4/4A Too Many Wires? Wiper Motor Triumph 9
S TR2/3/3A Exhaust system - It hangs too low no matter what I do Triumph 15
M 1275 too high? Spridgets 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
JPSmit Pre-War Is it too early to write Santa? 1933 MG J1 MG 13
CJD General TR Too Rude Triumph 13
AUSMHLY 64 front end too high Austin Healey 14
S TR2/3/3A OMG problem—the doors are too tight Triumph 12
T TR2/3/3A Turn Signals Blinking too fast Triumph 2
M Fat Feet hitting too many pedals Austin Healey 23
DrEntropy MGB Differential with too much lash MG 5
Got_All_4 TR6 TR6 engine rebuild. Too tight? Triumph 23
S TR2/3/3A New shocks too short? Triumph 7
BoyRacer Fuel tank sealing rubber is too thick Austin Healey 3
HalLucy Post-War Other Renown - Idle too fast Triumph 5
TRMark TR4/4A Seal too large for Surrey backlight Triumph 8
J TR4/4A Too hot to drive a convertible Triumph 14
S TR2/3/3A Too much fast idle, not enough choke? Triumph 0
TomMull TR2/3/3A New Top Too Tight Triumph 14
K Too lean? Austin Healey 2
Jim_Gruber What Now, new gas tank filler neck is about 1/2-3/4" too short Spridgets 19
warwick-steve How low is too low? [spring question] Austin Healey 19
Marla TR4/4A Carbs too lean? Triumph 11
D TR4/4A flywheel bolts maybe too long Triumph 15
kennypinkerton MGB Are my wheels too far gone? MG 8
wkilleffer MGB Fitting a new top to a 74 MGB- how tight is too tight? MG 23
3798j Boomers Too Old for Sports Cars Other Cars 8
PC Dang, that was too good to be true... Restoration & Tools 3
tr3guy TR2/3/3A New Wheel Cylinder too large Triumph 7
A rear brake drum too tight after rebuild Austin Healey 3
Jim_Gruber Bullet Connectors are too large to fit Tail Lamps on BE Spridgets 8
Got_All_4 TR2/3/3A Tr6 a type overdruve in my tr3 too long Triumph 10
TomMull Air Compressors, how much is too much? Restoration & Tools 7
Trevor Jessie Waaaay too much body roll Spridgets 14
Rut MGB Too many cars MG 31
KVH General Tech Transmission Drain Plug Too Tight? Triumph 5
T TR2/3/3A Is 5.5 lbs too much fuel pressure? Triumph 9
Martinld123 Why too much valve clearance after adjustment? Austin Healey 2
KVH General TR How Tall is Too Tall for the TR4? Triumph 3
E Spitfire How tall is too tall? Triumph 21
