martx-5
I know Paul has been interested in what's going with Tony's high idle problem since he went over to the Triple SU's on his TR250. He had Weber DGVs on there and always had all kinds of issues. I sorta talked Tony into the Trips, and he says the car has never run as good as it's running now. Well, except for that high idle problem. He has down work on the engine. Compression increase, a crazy cam (310 deg duration maybe), header etc. His tach in the car is out of whack, but that's another issue that I think I have answer to.
Anyway, we looked at the car today, and used an electronic tach attached to the coil for RPM readings. After the engine was warmed up, the tach readings were in the 1400-1500 range. Definitely too high. I printed out the info you guys said might be causing the problem and we went through the list. Surprisingly, the linkage between the carbs didn't appear to be causing any problems, however, I did notice that his carbs seemed to be way lean. He confirmed that, as he said he did lean them out. The carbs he has on there are the SU HIF type, which have a seperate enrichment screw on the side. I enrichened the carbs by just using the "lift the piston" method, and the idle dropped to between 1000-1100 rpm. He said he could live with that, but I thought that there still has to be a problem.
And what I did discover, is that one of his carbs (the front one) you could not really close the throttle all the way. I could adjust the screw, but at one point, it would just start to leave a gap between the adjustment screw and the carb body. If I physically pushed down on the screw, the throttle would close down more and the idle would drop. I think at this point, that the relationsip between the throttle shaft and the butterfly is a little out of whack, and not allowing the throttle plate (butterfly) to completly close down, or at least enough to lower the idle below 1000 rpm.
We ran out of time, but what I suggessted we do is take the carb off and see why that front carb is having a problem closing the throttle plate.
Anyone have any other ideas?? Especially these being HIF's. I'm not as familar with them as the H's & HS's.
