So, the plan in the near future is to ditch cable and get netflix and an HD antenna. The plan is to put the antenna in the attic and to attach to two TVs. The first TV will be only about 8 feet from the antenna but the other will be probably 40-50 feet away by the time the cable is chased through the walls and along the basement ceiling. At the store they suggested I use an amplifier, which requires a receptacle to plug into. Hence the question - do I put the amplifier at the antenna end (which requires me to install a receptacle in the attic) or in the basement (where there is already a receptacle. (Guess which I am hoping for?) any advice gratefully received.
