The specs I have found for MGB toe-in are 1/16 to 3/32 in (1.5 to 2.3 mm), which I believe is measured at the rim.
I have some good local shops that will do an alignment on an older car, but those machines all need the toe spec in degrees. Wondering if anyone has done that conversion and has the degree spec handy? I can do the math and figure it out, but don't always trust my geometry work as it's been a long time since I was in high school and had to solve a right triangle.
