Todays tip
jlaird
Gsskets from Moss for the tops of the float chambers were just a bit small to go on. I mean they would not go on.
Set down in front of TV with a peice of rather fine sand paper and actually sanded the insides just a bit larger.
Fit now.
Good solution, thanks
Jack, I though your carbs were fairly new and in good shape. Why did your gaskets need replacing?
. . . wondering if I need to check my carb/float gaskets . . . :rolleyes:
Ethanol Crud....
Aye Ethanol Crud. It really ate up the rubber gaskets especialy.
Well, and I got to mess with something. Float valves were nice and clean though. No corn oil works great.
