T
Tinster
Twin carb conversion to cable assembly.
Step No.1- disconnect battery- done
Step No.2- remove existing carb linkage - oh my!
Is the carb linkage the folded metal assembly between the carbs or
is it the threaded horizontal piece from the throttle shaft to the vertical arm between the carbs?
OR - the carb linkage the entire shebang in the photo?
Stuck on step No.2 does not look promising for a successful
conversion install!
thanks,
conversion install!
thanks,
Hi Guest!
