Good morning friends, Ms. Triss is getting perilously close to drivable which is great because the weather is getting perilously close to being drivable in.
At least a year ago I noticed that the vacuum advance unit was hanging loose on the distributer. I found a screw and reattached it but it was never really tight. I then forgot about it until last night when I noticed again.
So, it is attached but it is not snug by any measure.
It is important to know that I don't have the vacuum hose hooked up. Back in 2011 at the 50th in Elkhart Lake Jeff Schlemmer suggested that I not worry to use the vacuum in part because the 1500 California cars had vacuum retard not advance. So it wasn't doing anything.
So. Do I worry? would a slightly loose unit be doing something inside? any thoughts?
thanks all!
thanks all!
