Todays fact
jlaird
H1 and H2 intake manifolds are different sizes ie bolts for attaching to carbs etc are further apart.
ARGH! You have one of each, hopefully?
I have the one I need, but had to make a bunch of gaskets.
Intresting exercise these H1 carbs, my last Bugeye had H2s.
Now I find I need a spliter for the fuel line, always something, it never ends it seems.
If you still have the metal pipe that goes between the overflows on HS2s, you could cut the T out of that. It would look more authentic than a plastic T. I looked in Moss and VB and didn't see the part you need.
I do not have a set of H2s so I guess I am looking. I will not use a plastic T, maybe I can hide one under the carbs somehow.
Looks like I also need a Pin assy throtle spring but Moss does have them.
At this point it seem like there is always some little bit that is not in my stash of stuff. /ubbthreads/images/graemlins/nopity.gif
