jlaird
Have crankshaft, new pistons, old rods and pistons, cam and two heads in back of truck, off to the machine shop soonish.
Oh also front engine mount plate as it needs the two holes near the crankshaft opening counter sinked for flat screws rather than bolts so the double timeing chain and gears will clear.
Shop is going to fit .040 over pistons, counter sink plate, recondition rods and balance them, install pistons long as they are there, balance crank shaft, and check rod and main bearing sizes, think they are standard. Rebuild head and level same.
I will have an engine to put in when I get to that point.
Hi Guest!
